Old 06-26-2014, 05:16 PM
jhirasak's Avatar
jhirasak jhirasak is offline
Cobra Make, Engine: 331 SB, AFR heads
Default Secondary Springs
You should not feel a bog or a change in the rate of acceleration if the correct spring is used. If you feel a bog, the spring is too soft and allows the secondaries to open too early. If you feel a change in acceleration when the secondaries open, the spring is too stiff and the secondaries need to open sooner. If there is no spring available between these two conditions, I would elect to use the stronger spring and avoid a bog during acceleration.
