Old 07-01-2014, 04:12 PM
patrickt patrickt is offline
Originally Posted by genolan View Post
How tight should the zip tie be and why wouldn't the secondary shaft spin in both open and close directions and not move the zip tie at all, Or move it when it opens and move it back when they close.
The zip tie should be "handshake tight." That means tight enough to stay put on a rotating shaft, but loose enough that the shaft can rotate within it. When the secondaries open, the shaft rotates in a counter-clockwise direction. The zip tie rotates normally along with the shaft, but it is stopped by the throttle screw, so the shaft continues to rotate "inside the zip tie loop." But when the secondaries close, the shaft just rotates back clockwise and the zip tie stays fastened to the shaft in the exact same position. The zip tie will always register the maximum amount that the secondaries opened during a test run.
