Old 07-09-2014, 04:53 AM
saltshaker saltshaker is offline
Cobra Make, Engine: Contemporary Cobra
Default Air correctors
Paul, Emulison tube determine when the fuel starts to enter the main circuit. The 120 is a idle jet holder for the idle curcuit and the air corrector is for the main circuit, they are a aid to either lean or richen the jet. They have nothing to do with when the fuel transfers from idle to main... That is done by the emulsion tube. If your motor is a FE then I as many others found F11 tubes to work
You can call me if you want to talk
Jon
4844109570
The Impossible Only Takes A Little Longer
