Thread: fan cooling
Old 07-15-2014, 04:35 PM
Xack's Avatar
Xack Xack is offline
Cobra Make, Engine: West Coast Dreams
I apologize for being negative. However, I did say that "if it works, great". If your after a fix that works for you, then more power to you. I'd say that normally, fixes are just that, attempts to cover, mask the real problem. The underlying problem still may exist and get worse without you knowing it. Typically you want to shroud fans for safety, and efficiency. a properly designed and maintained system will keep everything cool in almost any driving condition. I am not judging you or your solution as much as I was just commenting on the photo.
