Old 07-17-2014, 11:34 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by genolan View Post
BXX1 this makes sense can anyone give me a reason not to switch to Mobile 1 0w 40 from Castrol 20w 50. I have roller rockers but have no idea on bearing clearance. I took the car for a hard run last night and noted the pressure at idle 900rpm before (65PSI) and after (25psi)
No reason not to try a 0W-40 oil, and see what your hot pressures are. If they're too low, then go back to the "thicker" oil.
I'm not a huge fan of Mobile 1. It's not bad oil for most vehicles. It's not a true synthetic oil, but it's priced like one. IMO, that makes it a bad value.
Even in New England, a 10W-40 would not be a bad choice. 10W is rated down to -20*. So unless you're driving at temps lower than that, there's no need for a lower viscosity.
If you want a wide spread like 0W-40, you'll need to switch to a semi-synthetic like M1 or Syntech, or one of the 4 true synthetic oils.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
