Old 07-19-2014, 03:21 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by mnm99 View Post
My car is boosted and need more than 12PSI. Asking how high it will go up to. I don't have a FP gauge yet so I cant check for myself yet.
Running a boosted carb without a fuel pressure gauge is flaunting with danger.
Your pump is factory set at 12PSI. Edelbrock makes no mention of how high you can go. You could probably get 20 PSI at the pump bypass or locked out. Then you also need a boost referenced pressure regulator as above.
Gary
