Old 07-21-2014, 05:55 AM
madmaxx madmaxx is offline
Do as mentioned above, in addition there is Allen head screws on the block toward the back you can remove to completely flush block, but that's extreme. The brown gunk u see is probably leak sealant. Once you flush the system you will discover leaks around the horrific water pump design. I would drain and flush raidiator. Fill with water drive flush, install antifreeze. Distilled water in this case is like marking a piece of wood with a 5mm pencil and then cutting with an axe. Use at minimuim 180f thermostat.
