Old 07-21-2014, 11:48 AM
DAVID GAGNARD's Avatar
Easiest way to flush the engine is remove both radiator hoses from the radiator,you'll also need to take out the thermostat.......
then stick your garden hose in the top hose a few inches and turn on the water full blast,it will go thru the block and out the lower radiator hose....
David
DAVID GAGNARD
