Old 04-11-2002, 12:02 PM
webebob webebob is offline
Cobra Make, Engine: SPF
The springs will unload when you raise the car. The outboard bolts are straightforward. The inboard bolts will change wheel alignment if you dont put them back where they were. Scribe a mark on the offset washers to aid reinstallation.
Count spacing washers in each joint prior to bolt removal. The washers will fall out and must put in the same way they came out.
Good luck.
Bob
