Old 07-22-2014, 05:35 AM
ERA 778's Avatar
ERA 778 ERA 778 is offline
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
I went through a very similar exercise recently. My 428 started missing and occasionally backfiring and I tried everything. I also have MSD ignition hardware and eventually swapped out everything before determining that it was the coil. In my case it was the epoxy filled high vibration coil, but I suspect heat to be the source of the failure. My coil is bolted to the front of the driver's side head and gets really hot. I ended up remounting the coil with a large insulator that I think will keep it a little cooler.
Never could find a temperature spec. for an MSD coil, but the new mounting dropped the coil temperature by 10-20 degrees.
Hal
