Thread: push rod length
Old 07-23-2014, 07:01 AM
crenbbf's Avatar
crenbbf crenbbf is offline
Thanks guys
A quick round up
The engine is an FE fresh build with an Eagle 434 stroker with lunati 272 Voodoo hydraulic roller cam. The rockers are Procomp .If I run the 'rods up tight to the rocker maybe 1/16" clearance I'm at 8.5" on the dot.
When I turn over the engine the roller runs over the extent of the middle third of the valve stem.
my measuring tool was supplied with the kit and has to be said not to hot
There is no provision for shimming the pedistals with the kit.
Rick, the target top end would be no more then 5500-6000 rpm since the car will be street only.
cheers
