Thread: push rod length
Old 07-24-2014, 12:28 PM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
If you change rockers you'll need to re check your pushrod lengths again, unfortunately there is NO standard geometry. I found it better to have a small width for the witness mark than to have a large wider mark more centered on the valve tip. There is a compromise, you certainly don't want the marks on the extreme outer edges of the valve tip.
Lou
