Old 07-24-2014, 07:19 PM
ERA 778's Avatar
ERA 778 ERA 778 is offline
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
Something doesn't sound right or I am missing something. For the MSD 6 series of ignitions, there should be two wires from the box running to the coil. There should not be a ground wire at the coil. Both the orange(+) and black(-) wires should run from the coil back to the MSD box. I suppose that if the engine ran before with the coil wire grounded, then an intermittent connection could explain your problem, but I just don't know if an MSD system can run if wired the way you described.
Also, if the problem actually was with the coil, relocating a bad coil should not fix the problem.
