Old 07-25-2014, 06:14 AM
ERA 778's Avatar
ERA 778 ERA 778 is offline
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
OK. That makes sense. A loose ground wire for the MSD box would certainly cause a problem! Mounting the coil upright is the right thing to do. Make sure you drive long enough to get everything really hot under the hood. My problem would sometimes come and go with heat under the hood.
Good luck, but I think you found your problem.
