Old 07-27-2014, 07:39 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Get a grinder and smooth the trransition ......imagine the throat of the carb.....ie the venturi.......ifvthe intake port has a narrowing at the join it will work like a venturi..if so shaped...which speeds up the gases at the exit....which is right at the valve ....so some gain for sure.....making them all the same is going to make it run smoother.....
