Old 04-11-2002, 06:07 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Almost enough to give you a hard on, isn't it??? P, you must have ordered the muffs with extentions welded on. Mine were straight bullets, and I had to weld my own extentions on.
With the 30"ers, I cut the turn out off the CR, and welded it onto the new bullet. You may have to do a trim, and slip fit. Same with the foreward end. Be careful with the OEM CR pieces. Metal is awfully thin. The Pages are pretty heavy duty. You won't believe your ears when you fire it up.
The 36" x 2 1/4" are really mellow. You can carry on a conversation in the car without yelling...until you give it a little throttle.
