Old 07-31-2014, 06:29 AM
rsk289's Avatar
rsk289 rsk289 is offline
Cobra Make, Engine: 289 leafspring, r/p
Is just one shifter rod hitting the crossmemeber - or all three of them?
The lowest by a long way is the Reverse shift rod, which tips down at quite an angle over the crossmember. This is the one that calls for any spacer to be 1" thick - the 3/4 rod may foul the xmember but by much less and would work with a thinner trans mount spacer. Can't really tell unless I remove the reverse rod and retry.
The 1/2 rod is completely clear.
Maybe experiment by redrilling the reverse lever plate, repositioning the reverse rod, and seeing if it still works...
It's a Tiger toploader, btw
