Old 08-01-2014, 06:04 AM
STEVE-O STEVE-O is offline
Originally Posted by Clois Harlan View Post
Hey Lou,
The other ground wire that you found on your coil goes to your tachometer I believe. Also, when you have some time check all your header connections to see if they are tight, just for grins. At some point these will work loose and possibly cause a backfire (usually on deceleration). Both Ricks, Tommy and others are right about backfires they are different depending on whether they are electrical or mechanical.
Hope you are have some fun in your Cobra now that you have things sorted out.
Clois
When using an MSD ignition, the tach wire comes from the MSD box and not the coil. The coil should only have a black and orange wire connection from the MSD box.
