Old 08-03-2014, 08:47 AM
ERA Chas ERA Chas is offline
Originally Posted by PeteF View Post
Can someone explain what's physically different about speed bleeders and how they help the process? The pictures I see on the internet don't clearly show me what's the benefit. Thanks
They have a check ball in the bleed passage. As you suction or pump fluid, the ball uncovers the passage port. You loosen the hex and that allows fluid to flow out but when you stop, the ball blocks air from being drawn in.
No pumping or second person needed. When fluid is clear with no bubbles, lock the hex.
To prevent air bubbles at the hose connection, coat the nipple with antiseize and use a zip tie if needed.
Chas.
