Old 08-03-2014, 10:09 AM
LightNFast's Avatar
LightNFast LightNFast is offline
Cobra Make, Engine: Viking Blue "64" 289 FIA comp car by Superformance #0002, Keith Craft - 331 (460HP), Jim Inglese - 48IDA Weber carbs, BW T10 4spd.
Congrats on your modification.
I believe the only difference between the Tiger and Galaxie is the tail housing length. You can see from the photo the original T10 configuration has the 3-4 lever just above the frame member - The Toploader should be nearly identical.
It sure sounds like the drivetrain isn't sitting correctly in the chassis.
