Old 08-03-2014, 10:17 AM
rsk289's Avatar
rsk289 rsk289 is offline
Cobra Make, Engine: 289 leafspring, r/p
Originally Posted by LightNFast View Post
Congrats on your modification.
I believe the only difference between the Tiger and Galaxie is the tail housing length. You can see from the photo the original T10 configuration has the 3-4 lever just above the frame member - The Toploader should be nearly identical.
It sure sounds like the drivetrain isn't sitting correctly in the chassis.
I had an idea that the side rod arrangement on the T10 is different from the toploader. Are they the same?
Certainly at present the tail of the toploader is sitting quite low with ref to the diff flange. I haven't got a motor on the front of it so can't tell until that's in.
The top of the 'chocolate block' rubber mount is roughly level with the top of the crossmember. As far as I can see that is correct, unless someone can tell me I've got it wrong. I may need some spacing anyway to help with driveline angles, but I think the T10/toploader difference is in the side rod arrangement.
