Old 08-03-2014, 03:24 PM
blue sky blue sky is offline
Roger, Check on putting spacers of the same thickness above the 4 bolts of the motor mount to block as you need between the trans mount and trans so that you raise it level. I had to raise a SBF with T-10 on a Mk3 car 1/2" to give better clearance for the shifter rods and had plenty of clearance above the air filter and header tank.
AJ
