Old 08-06-2014, 09:32 PM
454chevy's Avatar
454chevy 454chevy is offline
Cobra Make, Engine: unknown with a 351 windsor with aluminum heads
it has a nine inch rear. I thought that the door hinges, the framework in the grill, the gas tank, and the aluminum work under the hood(pictures don't do the aluminum work justice, doesn't look one off) would be more glaring clues as to where it originated. Past owners were of NO help. I drive my stuff and am concerned about origin because if I smack it up, I need to be able to put it back together again. I will post pictures from farther out and see if that helps anybody. Thanks for the input so far, even the bad, this car will change as time goes by....
