Old 08-09-2014, 01:50 PM
DanEC's Avatar
DanEC DanEC is offline
Default Replace alternator?
Looking for thumbs up or thumbs down on my slightly crispy alternator. While waiting for the replacement wire to arrive from ERA, I pulled the alternator out to take a closer look at it. The factory plastic insulator was fried more than anticipated. I removed it (I think it actually extends all the way through the hole in the case but it came off pretty easily).
I rigged up a replacement insulator and set it in a small bed of silicone caulk around the stud and came up with this as a repair. I ran the car after fixing the fried wire temporarily and it runs and charges fine. It does not appear to have actually ever managed to short to the case or anything else. The loose connection just generated a lot of resistance that caused high heat - it even melted a small spot out of the stud.
I put it back on the mount with the intent of running it this way but after reflecting a little I'm having second thoughts. I'm afraid the remaining insulator where the stud penetrates the case may be so crispy that after a few miles it will short through to the case.
Think I should just bite the bullet and replace it?
ERA 782 Running
