Rear end chassis mount
I have a 67 E-M with C4 suspension. The nut and bolt assembly that secures the Corvette rear end to the chassis came loose. I want to replace the old rubber bushings and hardware, but should this bolt be completely tight or should there be some play? Has anybody just used a nut and bolt (steel washers) without the rubber inserts which would secure the rear end solid?
