Old 08-11-2014, 03:29 PM
Ant Ant is offline
Default Carb
Frank,
I checked it out with Pro Systems a few weeks ago, Patrick said it was a street carb not a race carb and if I fit road race floats that should get me going..
As I intend on doing a bit of racing and being reasonably serious with my build I am very curious to find out if a street carb is a disadvantage or try a race carb, although only testing will prove that and a race carb might have the same top end as my current carb and be less drivable.
The 840 cfm is a good size for my engine, made great consistent solid power from 4000 - 7200rpm when I did some dyno testing.
Originally Posted by Frank Messina View Post
Just because it's 10 years old doesn't mean it's worn out or not a good piece. 675 HP from a 373 is pretty stout. Why not check with Pro Systems to see what updates if any your current carb might need to match your intended use. You may be shocked to find out it's good just like it is.
Frank
A J. Newton
The 1960's rocked!
