Old 08-11-2014, 03:33 PM
rodneym's Avatar
rodneym rodneym is offline
Full Blown Member
Premier Contributor
Default Easiest windshield removal
I'm in the process of brushing my previously polished stripes.
I need to remove the windshield to access the stripes underneath.
***All I need is access to the stripes*** I'm not replacing anything.
The way I see it, I can remove the entire assembly (with brackets/legs), or just the windshield/frame from the brackets/legs.
Since the brackets are nut/bolted to the frame, I foresee a royal PITA. The nuts aren't easy to access, believe me.
When you guys remove or replace, how are you doing it???
rodneym
