Old 08-14-2014, 04:49 AM
400TT's Avatar
400TT 400TT is offline
Hail427, I was assuming you would draw cold air from underneath the car directly to the rear of the alloy ducting for that scoop. You could just come straight out of your throttle body at the front of the engine, directly vertical and create an air box with pod inside that draws from the bottom. We do this in some of our mid-engine cars and it works a treat.
Originally Posted by sambo View Post
how are the front control arm mounts located in the chassis, a threaded insert of some kind? They don't appear to bolt right through.
Solid machined alloy crush bush that goes through chassis tube and welded. Bolts go all the way through. Expensive considering the number of bushes we end up installing in the chassis, but we wouldn't settle for anything else.
www.absolutepace.com
