Originally Posted by TimG427
I have a small dent on my Kirkham #561 just in front of the drivers’ door. I purchased the car with this dent, it is pretty insignificant. I can access the area from behind the dash, but I've been hesitant to try to do anything for fear of making it worse. Does this appear repairable by a novice like me?
If it were me I would check locally for a "good" paintless dent removal guy and let him do it. Keep in mind, paintless dent removal is only as good as the guy doing the work. A skilled guy can remove that very easily as they are used to doing it on steel panels and the aluminum should be easier to work with. If you want to try it yourself, I would call Kirkham and ask for some pointers.
Good Luck with it!
