Thread: Update ob Build
Old 08-14-2014, 03:57 PM
jarheadbpa's Avatar
jarheadbpa jarheadbpa is offline
Cobra Make, Engine: Lonestar LSC427/Engine Factory 427 stroker
Originally Posted by bktlist View Post
Suggest you ask LSC to take a look at your upper A arm install. The spacer plate may prevent you from acheiving an optimum alignment - it did for me using the A arm assembly you have installed and therefore may need to remove and grind out some of the frame plate for correct make up. Also it looks like your ball cup is upside down. I had to take my apart and flip but again LSC should now be up to speed and have issued a technical bulletin and updated their on-line instruction manaual to reflect correct installation
Which ball cup are you referring to? My version of the assembly doesn't even have the new upper A arm in the whole thing.
