Old 08-18-2014, 01:14 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
If you use wire ties get some 1/2" rubber hose maybe 3" long then take a razor knife and slit the hose long wise then wrap around the brake lines, then use the wire ties over rubber hose that way you won't be rubbing a hole in your brake line. It will happen if you don't use something to protect the lines.
"Let's roll"
"Be part of Something Good
