Old 08-19-2014, 03:43 PM
Igofastr's Avatar
Igofastr Igofastr is offline
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
Minimum, do a compression check, better still, a leakdown.
A compression check will give you a decent idea of the condition of the engine, but a leakdown test is much more informative as you get a better idea of how (bad ?)the wear is, and a pretty good idea of where the problems are (ie valves, rings, guides, etc).
The tools are cheap, except you'll need a compressor to do the leakdown.
I always look at the oil..at least pull the dip-stick and run the oil through my fingers. Look at the bottom of the engine...is it dirty, where, has it just been cleaned?
With a factory car, look for maintanance records...probably won't get much with a cobra...who built the engine...can you talk to them, are they still in business?
That's what I'd start with.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
