Old 08-22-2014, 07:21 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
Well this just did not work. The bolts that hold the caliper on were not accessible from underneath. So I removed the tunnel to get at them. Got them loose but the caliper still would not come off. I then disconnected the brake line, and driveshaft and dropped the entire rearend. It would not drop enough thus I had to remove the gas tank. I then dropped the rearend. After trying for an hour, there is not enough room to get the caliper out of the cage. Caliper is loose but with the emergency brake portion there is just no room. I am not sure what to do next.Here is a picture of where I am at.
