Old 08-22-2014, 08:58 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Default Kwiklift Users: What Bottle Jack Are You Using?
Hello all,
I have my Cobra parked proudly on a Kwiklift with 4 flat Billboards that need to be replaced (Yea, don't ask).
I have two of the Kwiklift bridges that will support the car's weight on jackstands while on the lift and allow removal of the wheels / tires. So now I need to get it up in the air corner-by-corner then insert the jackstands on the bridges and under the frame tubes. The standard method from Kwiklift is to use a bottle jack mounted on the bridge to raise the car enough to insert the jackstand. That's all good, but not so much when you are on flat tires.
Any experiences with this scenario and bottle jacks that might fit or other experiences doing something similar with a Kwiklift are much appreciated.
Thanks!
