Old 08-25-2014, 07:37 AM
joyridin''s Avatar
joyridin' joyridin' is offline
No gas cap on the fender.
Somehow, I would bet this is either a CMC or Streetbeast Cobra. The inner fenderwells were put together using pieces you cut out from another section of the body. The trunk was probably removed because it was molded so far off they had to cut it out to make the body straight.
Just a guess, but with some digging on here and the internet, these were pretty common problems. Putting a CMC or Streetbeast together was not an easy task as the instructions were vague and the fabrication skills required in many cases were way beyond the average garage mechanic.
