Thread: Radiator hoses
Old 04-13-2002, 07:08 AM
Jim Werth Jim Werth is offline
Cobra Make, Engine: B+B 351w #112
Lower radiator hose is a short hose that goes to the steel pipe that goes under the crossmember and back up to the water pump where you use a 6-8 inch straight rubber hose to clamp to the water pump. A steel pipe is used under the crossmember instead of a rubber hose because it is close to the ground and should hold up better. Jim
