Old 09-01-2014, 05:00 PM
hercf16's Avatar
hercf16 hercf16 is offline
Default 8 stack FI issues
Roush 427R, Imagine 8 stack FI, MSD 6AL, MSD Blaster 2. All controlled by
Easy EFI 1.0.
Have AFR set at 14.2 idle, 14.5 cruise and 12.8 WOT as per Imagine FI in AZ.
Set up run but don't exactly know what to put for fuel pressure and flow.
Starts, but needs a bit of throttle even after the pre squirt, and idles ok, set at
1000 rpm as per Roush 427IR specs. Revs and runs fine with no load.
When driving the AFRs don't seem close to the set values but runs ok until
I give it a bit of throttle as if to pass, then it hesitates/bogs down. I was
watching the AFR today and it went from 13. 6 or so to 15.9 when giving
it that throttle amount. Also does it leaving a stop in first gear unless I rev
it a bit first.
Thoughts?
Herc
Herc
