Old 09-07-2014, 06:06 AM
patrickt patrickt is offline
Originally Posted by lippy View Post
Nice write up Patrick. I think I'm going to try that, at some point.
Total, this was about a two hour job with a cost under $50. The majority of your time is spent sitting at the table soldering in the diodes to wires, soldering the wires to the switch, and soldering the fuse to the wires and flasher. Once you do that, especially if you're using Posi-Taps, it's about twenty minutes or so.
You know, I looked on the Internet to see if you could just order "pre-wired diodes," kind of like fusible-links, but you can't. Soldering in five diodes, then shrink tubing them, is half the total task. Once you do your "at the kitchen table" work, and armed with three Posi-Taps, you can knock this out in about a half hour. I had been planning on doing this for years, but when I ran across the 1966 Mustang Flasher Switch, I couldn't really put it off any longer.
