Old 09-07-2014, 06:55 PM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
For your next trick...any chance you have a fix so the brake lights work with the key off ...like a normal car? I have always thought was a safety hazard. there is nothing much I don't love about the ERA car, but this is one of them.
My last Cobra worked like a normal production car, brakes lights worked all the time, key on or off
If you have a mechanical fuel pump, just jumper across the left (meaning passenger) sides of fuses one and five. Those are the two top fuses on the right and left hand side of the fuse block. Then disconnect and just tape off the feed to fuse five. If you have an electric fuel pump then you'll need to place it on a switch.
EDIT -- Easy Test: Just remove fuse five and use a fused jumper wire with alligator clips to go from the passenger side of fuse one to the driver side of the empty fuse holder five. Leave that fuse out. That's an easy test to see if changing the feed will do what you want.
