  #41 (permalink)
Old 09-08-2014, 04:15 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by davids2toys View Post
Your problem of the intermittent jumping around sounds like it could be the end of the tranny gear. If I am right, it will get worse as the square drive gets more destroyed until just won't work at all. The good thing is this gear was designed to be the sacrificial lamb, that is why it is plastic and cheap
My initial success reveresed upon pulling the reverser apart and cleaning it out and lubing it with break in lube. Everything topside is lubed, graphited and shimmed to close tolerances, so I suspect I'm losing my plastic gear in the transmission. Anyone remember which speedometer gear goes with a 3.31 rear - 18 tooth??
ERA 782 Running
