Old 09-08-2014, 05:19 PM
boxhead's Avatar
boxhead boxhead is offline
As others have said, the alloy case box is the weak one.
You want the steal cased P50 if you have many upgrades on engine.
If a fairly stock 302 then the W50 should also suffice.
From memory a steel case and alloy case are both physically same dimensions outside, so a swap in your case should be faily simple.
I have a steal case I am using on another project, If need be I can put a tape measure over it to see if dimensions are the same.
Cruising in 5th
