Old 09-11-2014, 02:01 PM
jimbo01 jimbo01 is offline
Cobra Make, Engine: Backdraft #832
While changing the fluid in the clutch slave cylinder as advised by Backdraft to do on a regular basis I found the slave cylinder bracket moved as mush as 1/8". I was told this was normal and would not effect the shifting. After discussing this with a number of other mechanics this is not correct in anyway. I removed the 3/16" bracket on the car and had a shop manufacture a 1/4" 4130 aircraft steel bracket. Now the bracket does not move and adding an adjustable rod from Rose Hill Performance Parts the push rod is adjusted correctly and the trany shifts far better than before.
