Old 09-11-2014, 07:04 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
I do have 3" bilge blowers sucking sir out of the footwells. I have the blowers wired via a three speed control and I love the option on a long drive when I can set on low. Passenger has her own control.
My blower system is hooked into two independent heaters and allows you to blow warm air into the footwell too, and yes I have used it. Reversing the blower via a DPDT switch sends the hot air to the de-froster vents on the dash when needed as a defroster. I have not used the defrost mode as I've never had the hardtop on the car.
Mine are a little noisy on high as these move a lot of air. I will try to dampen the sound with appropriate materials and cover with foil tape.
