Old 09-13-2014, 05:11 PM
blykins blykins is offline
Block is back at machinist to have a little more whittled away at the cylinders. Rotating assembly will be dropped off on Monday to be balanced and to have the rod journals cut down by about half a thou.
Heads are assembled...Ferrea 5/16" stem valves, PAC springs, Comp titanium retainers, Viton valve seals. Each spring install height is checked and adjusted. Valve spring pressures came in at 285 seat and 720 open.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
