Thread: Wolf 3d maps
Old 09-15-2014, 03:40 AM
albanycobra's Avatar
albanycobra albanycobra is offline
Easy. for the flat spot...go to accel enrichment and increase until the flat spot goes away.just adjust then drive and adjust, make sure you savea copy of your current map so if you mess it up you can reload and start again....Also check your ignition timing has enough advance. For idle make sure the motor is running about 900rpm and adjust the idle mixture till you get a smooth idle.
