Old 09-16-2014, 05:54 AM
Nick 427 Nick 427 is offline
Cobra Make, Engine: RCM
I have the same problem same symptoms and have tried pretty much everything that you have.
I think I have solved my issues by doing the following
It seems that my brake bias is not applying as much force to the rears as other cobras and hence it is glazing the disc/pads
I jacked the rear of my car put it in gear and applied the brakes till they started to smell
I then went for a drive and the brakes felt better immediately.
I was cruising most of the day and the brake shudder reappeared towards the end of the day although very slight
I am going to do the same thing again only give it more revs and heat them up more than the first time and see how I go
I believe this is the problem and if the glazing keeps reoccurring I am going to fit a softer brake pad
Hope this helps
