  #33 (permalink)
Old 09-17-2014, 02:46 PM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Originally Posted by rsk289 View Post
OK, I'll bite - which missing section in front? Do you mean the bonnet/hood seal? And where were the drain holes - front two corners? -that's the bit that always dribbles more water when I dry the car after washing it...
The coachwork lip under the perimeter of the bonnet has weep holes drilled in the low front corners to let water escape. The drains often get covered with new seal strip after people repaint their cars.
Here again, if the gap in the seal (forward straight section) is micrometer measured perfectly centered I would not believe AC Cars installed it.
Dan Case
