  #53 (permalink)
Old 09-17-2014, 05:47 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Originally Posted by Gav View Post
The earlier square tube CR's have a X frame under the rear of the gearbox, its made from 80mm RHS so its a permanent feature.
Mike removed the cross piece that's under the sump on his, its 25x50mm RHS and I'm not sure what it is even there for.
I'm planning on removing it so as I can fit a later model oil pan on mine.
Yep, I made a removable engine cross member. It makes it possible to remove the sump with the motor in place.
Pulling the gearbox still needs the engine out.
Mike Murphy
Melbourne Australia
