Old 04-14-2002, 06:34 AM
Denny S. Denny S. is offline
Default Slipping Clutch.. Or Haunted Cobra .. I'm not sure..
After 3 days in the shop renewing every gasket from Thermostat
to Rear Main. New plugs,filters,thermostat, changing out all the fluids from Coolant ( Now 80% Water,20% Coolant and 1 bottle of Water Wetter. New gear lube in the toploader ( 80-140 Valvoline) Differential changed out to (Red Line
and a Tube of Equatorque ) New springs and limit bushing in the MSD Distributor ( Former owner had timing at 6 degrees initial
and 20 something max advance.Timing now at 10 Initial & 38 Max.
All this was brought about by numerous oil leaks and a blown head gasket. Head gasket I'm attributing to former owner getting it hot on his first runs after build. I back it out of the shop after we check timing and carb adjustment. Back it out into the road and drop the hammer... Clutch smokes and stinks and no wheel spin... I'm Pi**ed at this point AND it looks like it's leaking oil STILL
If it is in fact still leaking it could only be coming from oil galley plugs. So out comes the 428 or the toploader.. So I load it up on my rollback and take it home disgusted. Now here's the kicker.
I decide to repair the E brake cable ( 5th tIme) correctly and just put in a new one. I'm looking under the car and see that my half shaft on the drivers side is all shined up. Upon closer inspection I find that a Bolt had disapearred out of the rear suspension and the right rear unequal arms are wedged down on the axle. Anyhow I repaired that and checked every other fastener. So thats what that strange rattle was. No permanent damage
done , but I'll bet it woulda got ugly sooner or 140 mph later.Ok to end this tale of woe. How much travel does the Clutch Master cylinder have with a Mc Cloed Hydraulic Throw out. I think mine is overextending or my master cylinder is leaking by...
