Old 09-22-2014, 12:35 PM
Harley753 Harley753 is offline
Mark
I think we have the same radiator - it took me a while to decide how to mount the radiator because it did not fit in the old mounting brackets and I did not have any mounts on the top or bottom -
I wanted to insure the radiator was mounted to the frame - and the only place to easily get to the frame was using the original holes that the AL bracket was using with a side mount - I purchased 2 pieces of AL - 2" x .125" by 8' - it was long but it was available everywhere. I folded the first piece around the side - top - side - all the way to the bottom. I found the 2" fit perfectly in the top and bottom channel. The second piece I folded side - bottom - side with the first piece of AL in place - once this piece was made I came up about 8" and bent out about 1.25" at a 45deg and than bent straight up - on both sides -
I counter sunk bolts in the first piece of AL to mount to the second - fitted it with claps for a tight fit and put it together - the two AL strips hold the radiator very snug
I put a couple of mounting holes on the "ears" - so I could try different heights - and mounted to the rear frame hole. I had also mounted a couple of 1" AL to the top of the frame and connect those to the front of the frame holes -
On the hoses - because the radiator moved back a couple of inches the bottom hose no longer fit but all the others were fine
Hope this helps - good luck
jim
